O
OzziePete
line6man said:Cagey said:They don't need to be reefed in like lag bolts holding a work bench together. They're just there to keep the machine heads from turning, not to hold the things in. So, some of the rules you'd normally follow to run in a fastener aren't pertinent. It's not a fastener, per se. It's just an alignment enforcing device.
Exactly.
When you're putting screws in your headstock, though, make sure you WAX them well. It can mean the difference between a screw getting stuck and possibly breaking off, and going in smoothly.
I use wax from the Steve Vai signature meditation candles. That wax has a much better tone than standard candle wax. (Make sure to utter a short prayer first, to envoke the spirits of the guitar gods to materialize into the wax.) :blob7:
I bet Eric Johnson could tell what temperature the wax was burned at..... :laughing7:
