Firebird211
The page Cagey laid down best describes the basic theory behind the volume and tone control in a guitar.  At the heart of electrical theory the source, whether it's a battery or guitar signal, is drawn to the return to complete the circuit.  The return could be the negative side of a battery, or the ground of an entire circuit.  The guitar pickup is like a mini generator, where the vibrations of the string in turn induce a current in the coils, which is an electrical interpretation of the sound.  The hot end of the pickup wants to go back to ground to complete the circuit, and no current can flow unless this connection is made.  If the pickup has easy access to ground without a resistor, such as a volume pot in the way, the circuit is still operational, but you will never hear anything at the output.  Think of it this way, take a 9 volt battery, across the leads you will measure 9V because there is a very large(open) resistance between the two leads, but nothing is flowing until something is placed across the leads.  When the battery is measured the meter has an internal resistance that allows the current to flow to determine what the voltage is.  If you short the leads out, or like shorting to ground, other than the battery getting really hot you would not be able to measure the voltage across it anymore, that potential difference between the two leads does not exist anymore.  The output jack of your guitar is similar, but the signal voltage isn't like a DC battery, but the electricity behaves the same way.  If the resistance is there between the two leads, like 500k down to the smallest setting you can hear, there is as much voltage across the resistance according to that.  You are hearing the voltage amplitude of the signal.  You ground it out, and nothing is audible anymore.  You could think of it in terms like the signal is just pushing it's way through and into the amp, but internally the pickup is really just keeping to it's own complete circuit, and the amp is taking the small signal(sample) and amplifying it.  Just like ohm's law describes it current, resistance, and voltage all go hand in hand.  You can't have voltage without resistance and current.  You can't have current with an open circuit, but what ever device you hook up, whether a meter or amp, is completing the circuit and using the voltage.
		 .  But I hate switching guitars in the middle of a show.  I'd rather flip a switch, even if I'm the only one that understands how it works.  Besides, it's been fun.
.  But I hate switching guitars in the middle of a show.  I'd rather flip a switch, even if I'm the only one that understands how it works.  Besides, it's been fun.   ccasion14:
ccasion14:
