Cagey,
I know (parts schematics vs. wiring diagrams). But I played around with every single part to see how it worked, and they all work just like the switches in the diagram. I know this because I printed the diagram four times and traced the flow of electricity in each of the four push-pull possibilities. From my own testing, I can tell you the schematic is something like this:
When the pot shaft is pulled up, the switch connects the middle terminal on the left with the top terminal on the left, and the middle terminal on the right with the top terminal on the right. No other connections are made. When then pot shaft is pushed down, the switch connects the middle terminal on the left with the bottom terminal on the left, and the middle terminal on the right with the bottom terminal on the right. No other connections are made. The three terminals for the potentiometer itself work according to the traditional method, where the terminals on the left and right are connected, but inhibited by a resistor that sends a variable output to the middle terminal, which effectively serves as an output for the pot. The left and right terminals are essentially interchangeable, except that depending on which one you send to ground and which you use as input, the knob will turn different directions as it varies the output.
BlueFirebird,
That switch isn't wired yet. I have the pots wired, the output jack, and a kill switch wired, with three unconnected wires (neck output, bridge output, and hot wire to the jack) I can connect with test leads.
Sounds like I need a solder sucker...and more patience.
Thanks, guys.
(EDIT): I'd post a picture (and may later, for kicks), but there are something like twenty-two wires connecting these two small pots, not counting the grounded shields for the shielded cables, and the pots are separated by less than two inches. To me at least, it looks like a tightly interconnected mess of wires. It's hard to see what's going into any one terminal without taking the pots off the pickguard and bending everything into strange positions, which invariably breaks one of the shielded wires I bought from a company we all love, though I have come to detest their shielded wire.
