How to determine my warmoth neck specs and radius
mikes66
Hello, I have a parts strat I bought off of ebay which is awesome (warmoth neck and body) finished in relic'd fiesta red. My question is how do I know which warmoth neck I have? The back of the neck says 6130, which I assume are the med frets and also 1.681. any help would be appreciated, Mike
And the red dot signifies that you have satin nitro finish, if you weren't sure what it meant.
Right. You've got 6130 frets, a 1.681" nut, and a satin nitro finish. The radius and contour are unspecified, but those can be measured. The tuners are Kluson-sized. (I don't know the size, off hand.)
Print and cut some radius gauges and check them against your fretboard : http://www.pickguardian.com/pickguardian/images/pickguardian%20neck%20radius%20gauges.pdf
Measure the thickness of the neck at the 1st and 12th fret, compare with the specs : http://www.warmoth.com/Guitar/Necks/BackContours.aspx
