Cagey said:Actually, I would think you'd want shorter flash times. If you got runs/sags, the material was staying at a lower viscosity for too long, was being over-applied, or both. With the larger orifice nozzle, I can imagine it being difficult to keep from getting too much material on the workpiece. So, if you used any retarder, cut back on it or eliminate it entirely so it flashes off and firms up faster. If not, cut back on thinner. Next time, I mean. You're done with the big nozzle now, right? Should be down to the 1.4mm or 1mm opening. I prefer the 1mm myself, but I'm using an HVLP spray rig.
Cagey said:I'm not normally a fan of metal flake finishes............
DangerousR6 said:Awesome...I love 1970's speedboat flake.... :headbang:
Verne Bunsen said:Do you print your own decals or do you have them printed? I dig 'em.
6stringer said:Wow, that is really something!
DMRACO, was that originally a Warmoth build? I'd like to do a DC for my next project, but they don't seem to offer that body style. I thought I had heard they did at one time. Is it a bolt-on neck, and if so, how does it work on that, compared to the set neck of the Gibbys? Does it impede higher fret access like I think it would?
So many questions...![]()
