dmraco
Master Member
So I am re-doing a LP JR DC. This is Precision LP JR prototype. I was never happy with it. The neck was a HUGE 50s style...super thick. Also the humbucker neck pickup was too close to the neck causing a super unstable setup.
I ripped out the electronics I installed, (fishman) and drilled a new bridge. I filled three of the five control holes and filled the neck pickup cavity with epoxy. This really firmed up the body and eliminated the flex. Finally I got out the 50 grit sandpaper and power sander and went to work reshaping the neck. It is closer to the diaper of a standard thin but is a little flatter of a profile, kind of like the Ibanez necks of the 80s.
What this will become is an experiment in metal flake. Someone asked my on another build thread "where is the flake?" so I am going to make up for it here.
What you see now is the body with a red base and masked for some of the highlights. The guitar will have a faux flake binding. I cut it out by hand but as you can see I still have some places to even it out a bit. My eyes are crossed from cutting so I need to rest a bit.
Colors will be a ruby red and 24k gold with black accents. This one will stick out. I am even buying a new gun to accommodate the larger flake (.015 vs the .004 I usually shoot). I will retain the gold hardware and it will have a single bridge PU with tone and volume. Frets are gold too :headband:
