hollowed mahogany Tele + pau ferro/ebony neck + P94 PU's
Caisa
Hello,
what do you think about a hollowed mahogany Tele body with a pau ferro/ebony neck and P-94 (P-90s in humbucker size) ? Do you think the hole thing will be a good working combination?
I am not shure what kind of neck I should choose. It must be light enough that the axe will not be neck heavy with the hollowed body but  it must give the sound some more attack than a mahogany neck deliver so that the sound is well balanced!
It's my first Warmoth build guitar so be linient to me.
Caisa
NonsenseTele
Jack and other guys here that have Pau Ferro necks says that is one of the most heavy woods... So not a good guess...
I believe Gonçalo Alves would weight less and it's a little more bright than Mahogany...
Caisa
Ok, then Pau Ferro is not the way I will go!
Maybe Marple is better, but I do not know how it sounds with a hollowed mahogany body.
