Help me troubleshoot a loud B string
OneTanMan
I’ve made a Telecaster deluxe style guitar with two Gibson Custombuckers. The b string over loud, it’s the loudest string when amplified, but not acoustically. Here is what I’ve tried:
  • Lowered the b pole pieces and raised the e pole piece. This helped a bit at the bridge, but not at the neck.
  • Tested the same notes on different strings. They always right loudest on the b.
  • Raised the action on the e to avoid thinness due to fret buzz
  • Changed strings brands and gauges
I’m considering replacing the bridge from modern fender block to Callaham bent steel w/ modern spacing. I don’t think that would do much but I’m running out of ideas.
Louder than the G? The largest string core is the unwound G, then the B. That's why the B pole piece is buried beneath the cover on the vintage Fender stagger (Fender staggered for a wound G, with the smallest core).
How is the string height? is the B sitting any lower at the nut or bridge?
The truth is that the B, G, and E1 strings are made of wire, are not wound, and have a different inductance than the other strings.
You'll never achieve perfect volume with these strings.
Depending on which frets( how y us fingerboard generally) you play more often,
To balance the sound of the strings on your guitar, place a capo on the 5th or 7th fret and then adjust the guitar pickup settings.
More advanced settings typical for a Telecaster guitar and perhaps for Stratocaster-style guitars for the G string. If they are single-coil pickups at the bridge (Telecaster), you should check whether the single-coil pickup is designed for wound or wire strings. Different pin settings are available for wound and wire-coil pickups. You can modify the pin magnetization, but only if you have the appropriate knowledge. On start if G is too lound change G string on coat style
Changing the bridge fixed the problem somewhat. I think part of the problem was that the original builder did not tighten the bridge down enough which caused some weird resonances.
