ihavenothingprofoundtosay
I've started work on my Steinberger/Kramer Duke/Kubicki (Dukubicki?)-esque travel/practice bass (general details here), with the first of many coats of TruOil on the fretboard. I've also cut the purpleheart plank into 2 pieces to sandwich together. They'll need quite a bit more sanding before the fit is smooth enough to get it to work, but I'm getting there. Then I'll get to routing out the middle a bit to save some weight. The next big thing to do is make up a routing template for the neck pocket, which I suspect will take me several attempts. :sad1: I'll be practicing my technique for the ball end holder on the headstock before doing the cutting on the neck.
The rough layout is below, though I've obviously got a lot more cutting & shaping the body, but it gives you an idea of the scale.
EDIT:
- DONE! Pic here & probably more coming to my flickr stream (need to take a good one for the GOM :glasses10 Got it wired up last night & will spend the next few hours fine tuning the setup & intonation.
EDIT:
