I mount mine solid to the body, no springs. I put the pup's in loose and string it up, then use washers under the tabs to shim up to the height I want. It's a bit more time consuming, but it mounts the pup's directly to the wood. Instead of floating on springs.... :dontknow:tt0511 said:Just placed the neck order. :icon_biggrin:
SN6374 Stratocaster®, Warmoth Pro , Right Handed, Goncalo Alves, Ebony Fretboard, 1 11/16" Nut Width, Standard thin, 6105 frets, Schaller (25/64", 11/32") Tuner Ream, 22 frets, 10-16" Compound Radius, Cream Face Dots Inlay, Corian Nut, 25-1/2 in. Scale
Now, ....if they'd only ship it same day service for free! :laughing7:
I'm trying to determine how to mount the pups in this body. Yes, I know it'll be with screws. I've only owned one guitar with pups mounted directly to the body like this and that was an Ibanez RGT320. But it had big humbuckers. I'm using Blade humbuckers in this one (single coil profile). I want some kind of height adjustment to get the pups at the right height. Should I just pick up some springs from Stew Mac or a local tech? Or, is there a better way?
Blue313 said:Sweet neck!
Springs or foam will do the job to get the adjustability. You'll have to widen the holes in the pickup so they can slide freely though.
tt0511 said:I mount mine solid to the body, no springs. I put the pup's in loose and string it up, then use washers under the tabs to shim up to the height I want. It's a bit more time consuming, but it mounts the pup's directly to the wood. Instead of floating on springs.... :dontknow:
No,no,no....the tone worms won't be able to feel the vibrations....tfarny said:I think there are even people who machine a wooden shim of the correct height and glue it in, then screw directly to that. Personally I'd use one of these - http://www.stewmac.com/shop/Hardware,_parts/Electric_guitar:_Covers_plates/Metal_Mounting_Rings_for_Single-coil_Pickups.html
DangerousR6 said:I mount mine solid to the body, no springs. I put the pup's in loose and string it up, then use washers under the tabs to shim up to the height I want. It's a bit more time consuming, but it mounts the pup's directly to the wood. Instead of floating on springs.... :dontknow:
Very careful measurements......For hums it's best to not have the plunge cuts in the pup rout's, that way you have plenty of wood. But if the plunge cuts are already there, then I usually make some plugs to fit in the plunge cuts... :icon_thumright:Markoooooo said:DangerousR6 said:I mount mine solid to the body, no springs. I put the pup's in loose and string it up, then use washers under the tabs to shim up to the height I want. It's a bit more time consuming, but it mounts the pup's directly to the wood. Instead of floating on springs.... :dontknow:
Hey Doug,
maybe an obvious question, but I don't think I ever mounted a pickup directly in the body - how do you make sure you won't screw it through the back of the body?
