koshersteel said:
I realize that Warmoth makes bolt-on guitars but I was wondering what would happen if I ordered a body and neck without holes and glued the neck to the body and held it with a clamp for a few days until the glue was fully cured? Has anyone tried this? Is there an obvious reason why it wouldn't work?
what advantage does glue have over bolts? other than the glue on being fragile what's the diference?
it seems to be a common "understanding" that glue ons transfer vibrations better and that somehow gives more sustain. but where is the evidence for this? thories are great but science needs to be tested so why should ideas about musical instrument construction be different? even Ed Roman as much as he gets bashed on this site for some rediculous things he says doesn't fall into that wat of thinking and even says bolt ons have the sonic advantage, whatever that's worth.
if you do what you're suggesting i'll bet it holds pretty good if it is glued before it's painted,i can't garentee it being i haven't tried it, but you don't gain any high fret access, so where do you win? it's just extra work for the sake of an untested idea without garenteed results and posible structural problems. and you lose the ability to adjust for poor string alignment, if you botch it up it's alot of work to fix.
