Strat Avenger
Why can't we all just be the same and like the same things (LOL!!!)?
Anyone else ever play a YJM strat? I believe that not only has 6000 fret size, but it's a deeply scalloped fretboard!
I am a little concerned that you may be playing this guitar too often.I play the one I own frequently. It has 6000 size nickel frets and is deeply scalloped.
Naw, stick with 6100's.Dang it now I'm curious about 6115 frets, but I already placed the order with 6100
6100s are where it’s at.Naw, stick with 6100's.
You're right! I never realizedlmao dunlop 6000 is the same dims as warmoth/jescar 6100, y'all
I’m stunned!You're right! I never realized
Are you sure?lmao dunlop 6000 is the same dims as warmoth/jescar 6100, y'all
You can change your order if Warmoth has not yet started building it. I Imagine that at least if the frets have not been installed, they would let you change the size of the fretwire. Give them a call. Intonation is more precise with a more narrow fret (provided you're not pressing so hard that the note goes sharp).Dang it now I'm curious about 6115 frets, but I already placed the order with 6100
their very own "accu-wire" chart lists 58 x 118 for 6000, so yeah, i'm as sure as pauly shoreAre you sure?
Apparently soStratamania knows.
I think I'm just gonna stick with the 6100s. I'm planning on using 11s so the bigger frets should work well.You can change your order if Warmoth has not yet started building it. I Imagine that at least if the frets have not been installed, they would let you change the size of the fretwire. Give them a call. Intonation is more precise with a more narrow fret (provided you're not pressing so hard that the note goes sharp).
