DangerousR6 said:
-VB- said:
Are the strings going out of tune sharp? That most certainly indicates binding somewhere. The nut is a chief suspect as you mentioned. The tuners are also potential trouble spots if they are not locking and/or have excessive string wraps: the wraps will relax when the trem is lowered and when tension is restored they do not always seat quite as tightly as they were. A well cut nut and locking tuners properly wound will probably cure what ails you.
It's a Floyd, so most likely he has a locking nut and not locking tuners...
The nut is actually non locking, the tuners are though. It didn't go out of tune whatsoever before the string change so I think we can rule the tuners out. When going down and back to neutral, all the strings also go flat very very slightly (not noticeable), but the G string goes sharp just enough to make a difference (especially since the others go slightly flat). I think I'll widen the G string slot a tiny bit and see if that does it. Thanks!
