davegardner0
A friend dropped off an Ibanez RGA121 for a refret, and during my initial inspection of the instrument I noticed a pretty nasty headstock crack. My friend has no idea how long it's been there, or how it happened:
(In the last photo I'm pulling the crack apart a little.) The crack is definitely longer and has a wider gap on the treble side, and it's much smaller/tighter on the bass side.
Even though the string tension isn't pulling the crack apart further I'd definitely like to try to fix this. I'm thinking the clamping won't be too hard as the headstock has a flat spot on its back. However what I'm not sure about is how to get the glue inside the crack. I was hoping I could get some opinions/thoughts.
On one hand, I'd like to use fish glue as it's my favorite for instruments and seems to stick to everything (in case there is a little dirt inside the crack). I was thinking of maybe thinning it with water a bit, and then using a syringe to get it inside the crack. The treble side seems doable, but I'm afraid I won't be able to get glue very deeply into the bass side.
The other option I thought of is to use super thin super glue, like you'd use to glue frets that are already installed. I was thinking this would wick into the crack. But, is CA glue really good for structural wood gluing?
And last thought, since the crack seems to be all the way through, do I need to worry about gluing the truss rod?
