Nightsprinter
Can someone help clarify a few things for me? I just got around today to working on a build and have a modern construction neck I took delivery of a month or two ago. I noticed that as it was, while measuring with a notched straight edge, there was a hint of a backbow. So I backed the heel adjust off a bit and put it into neutral. The slight backbow still existed. So, thinking it is a true dual action truss rod, I backed the nut off expecting it to catch- but it doesn't. I didn't back it off all the way, but it appears like the nut will just thread right off like a single action would- i feel confident in this because it began to protrude from the heel and got looser and looser. Is this normal?
I then put slight tension back on the heel adjust nut and checked the side adjust mechanism. It also doesn't appear to catch counter clockwise, though I didn't torque on it and was being very careful and gentle to see how it works.
Am I misunderstanding the nature of modern construction or do I have an issue here?
This experiment was done without string tension. The frets need leveling so I was considering doing it neck-off presuming I could get the neck flat, but alas...
