Hi all,
This is my first post to UW, as well as my first project guitar. I'm starting fairly simple with a warmoth offset body and eventually a warmoth vintage modern straight 9.5" neck. I will be rerouting the body to accommodate a lovely red spitfire tort guard and will be finishing this one with wudtone's satin saffron finish. I've got a Novak JM-V for the neck, a JM-FAT for the bridge, and a lipstick for behind the bridge. This guy will also be getting the mastery M1-V kit when available (hopefully soon).
I did have a question... I want to use the rhythm circuit controls for the behind the bridge lipstick pup, but am pretty new to wiring guitars. I know I'm not breaking new ground here, but does anyone have any diagrams that retain the lead circuit for the neck and bridge pups and use the rhythm circuit for the BTB pup? I want to be able to blend the BTB pup at times and completely cut it off at others.
Here is a picture of what I hope the finished product looks like:
And a picture of my Novak's:
And a picture of my first wiring attempt (before I decided to go with the BTB pup--just practice on an old guard I had--good thing too, the solder was too thick, and my joints and grounds were admittedly terrible. Here's to my next attempt!):
A simple search revealed this circuit (thanks In-Sound). I'm wondering if wired in this way, I will be able to completely cut the BTB off via the switch, just like I would cut the rhythm circuit if wired normally.
I'm a little concerned that the above wiring would not allow me to blend the BTB pup with the lead circuit... i.e. I would only have a signal from the BTB OR the lead circuit, not a blend of both... But again, I'm terrible at this.
Anyway, thanks for checking this out, and I'll update accordingly.
