Dcguitar
I put together a Soloist body, with recessed floyd, and roasted modern maple neck (locking nut and compound radius). The floyd base sits about half recessed into the body, nut has no shim.
most of the notes on the high e string are choked and bending does not work above the 14th fret, the low is is similar (though not as bad).
Do i need to adjust the nut, or raise the bridge? Does the truss rod need an adjustment if so which direction?
I'm not comfortable making major changes to the neck / frets, and i dont have the tools or skills to do this, so if I should just take it to a tech, am I just asking for a full setup and showing them the pain points?
