First attempt at cutting a nut
timezon3
I have a new neck on order from Warmoth, and thought I'd try cutting a nut out of a piece of ivory* I had hanging around.  I used an online calculator with my desired string spacing and gauge and created a spacing diagram.  And I did the old feeler gauges -> gauged files trick.  The feeler gauges actually seemed to work pretty well, I was impressed.  The string spacing seems reasonable.  The nut is still way too high (probably needs an eighth of an inch or so taken off the bottom), but I think I could sand that down and potentially actually use this nut if I felt like it.  I also have a preslotted nut coming from eBay, and when it gets here I'll compare the two and decide which I end up using.  It was a fun bit of tinkering, though.
TZ
*I know, I know.  Let's just say, when I acquired this piece, 10 or so years ago, I wasn't as conscious about this stuff.  I wouldn't ever buy actual ivory nowadays.  It was advertised on ebay as from museum ivory, and pre-ban.  It being eBay, I'd put even odds on these three possibilities:  1 - actual pre-ban ivory;  2 - illegal ivory; 3 - not ivory at all, just some bleached bone.  Anyway, like I said, I had it hanging around, figured I may as well use it.
