forloveofivy
Hi All, I recently purchased an early 90s Fender Blues Deville 410. I decided to take on a fun project to convert it into a head. The biggest question I have at this point is if anyone knows what ohms the internal speaker jack is good for? I want to be sure I am using the cab properly. I know in the manual I read, it lists that you can use the external speaker jack with an 8 ohm cabinet, but there is no mention of the way the internal speakers are wired. Further, I am wondering if I should even use the internal speaker jack as the output to the cab, or if I should just use a "dummy" cable in the internal jack then run the external jack to the 8 ohm cabinet.
There was a similar question on the following thread, but I am just looking for reassurance as to if I should be running the converted head into 4 ohms or 8 ohms on the cabinet.
http://unofficialwarmoth.com/index.php?topic=11419.0
Also more generally, are there any other speacial considerations that anyone knows I should consider when doing this head conversion? Has anyone else done a similar conversion? Thanks.
