Super Turbo Deluxe Custom
Epic Member
Cagey said:That's how I do it. That braided shielding is a real pain in the shorts to unravel to the point where you can twist it into a wire. So, just strip a bit back to where you can clear the inner conductor and hook it up, then use a short piece of bus wire wrapped around the shield to create a lead you can use to tie the shield to ground.
Same here. It's even better when there's more than one shielded cable. I put the 2 together, wrap them both in the same portion of uninsulated wire tieing one end between the too and heatshrink it with no solder.
