Do you wanna build an Iceman?
Tretgeraet
Dearest Warmothians,
I'm just 5 weeks into the long wait for my Iceman body and Nomad neck, but yesterday I received the last piece of all the parts for this build that I didn't order at Warmoth: Perfect time to start a Build in Progress thread!
So, what DID I order at Warmoth?
Iceman Guitar Body
Construction:
Solid
Core Wood: Alder
Lam Top Wood: No Lam Top
Right / Left Handed: Right-Handed
Control Cavity: Rear Rout (Standard)
Neck Pickup Rout: Humbucker
24 Fret Reposition: No
Middle Pickup Rout: None
Bridge Pickup Rout: Humbucker
Controls: Volume 1, Volume 2, Tone 1, Toggle Hole
Jack Rout: 7/8" (22mm) Side Jack Hole
Bridge Rout Type: Tremolo
Bridge Rout: Schaller Floyd Recessed
Would you like Warmoth to install the bridge studs?: Yes, from a bridge I have on order.
Mounting Holes: Standard 4-Bolt
Neck Pocket Shape: Strat®
Body Contours: Custom Contoured Heel
Binding and Edge Decorations: None
Battery Box: None
Paint Category: Metallic
Top Color: Black Cherry
Back Color: Black Cherry
Satin or Gloss: Gloss
Nomad Guitar Neck
Construction:
Tiltback Gibson® Scale Conversion
Shaft Wood: Walnut
Fretboard Wood: Ebony
Nut Width: 1-11/16" (43mm) - Modern Medium
Neck Back Profile: Standard Thin
Fretboard Radius: Straight 12"
Number of Frets: 22
Scallops: None
Binding: Pearloid Binding
Fret Size & Material: SS6100 - Jumbo (Stainless)
Tuner Hole Size: Schaller/Modern Fender/Sperzel (25/64")
Inlay Shape: Split Diamond
Inlay Material: White Pearloid
Side Dots: Luminlay w/ Black
String Nut: R3 Floyd Prep w/ Mounting Holes
Neck Heel Shape: Strat® Shape
Finish: **Black Cherry Metallic Gloss Pegface - Clear Satin Nitro Back** (Off Menu: $245.00)
That Order also includes:
- Schaller Floyd Rose in Black
- Schaller S-Locks in Black
- Neck Plate, Neck Plate Pad and Neck Screws for Contoured Heel, all in Black
- Warmoth Metal Decal in Black
- 3-Way Toggle Switch, Straight in Black
- Low-Profile Pickguard Screws, in Black, of course
And a black-red-black pickguard blank, which might be part of some experiments...
What did I not order at Warmoth? Let's take a look:
Alright, there's some shielding kit, a bunch of wires, 3× 500k log push-push pots, a black Electro Socket, a black Gotoh wrench holder, some black screws, mounting rings and:
- Rockinger Alnico II Custom Neck HB
- Rockinger Destroyer Bridge HB
- brand new Schaller M6 Back-Lock in Black
- Schaller Sure Claw
And this is were I actually like that Warmoth sells their Floyds without Nuts:
- R3 nut with 12" radius, ordered directly from Schaller.
I also have some knobs, but I keep those a secret until it's finished!
Also, I think the M6 are actually in Schallers new black finish, while the R3 nut is slightly darker and less... shiny... but that doesn't bother me at all. I think it'll add depth and sparkle... you'll see!
"But why the Sure Claw?", you might ask, "It'll only add weight and Warmoth drills for the standard, perfectly good, normal spring claws, you fool!", you might add. "YOU FOOL!"
Yes, I know. I have my reasons. Actually, it's just one:
I want to play in D-standard and drop-C on the same guitar, with a free floating vibrato.
My purpleheart guitar has a sure claw and with that it's very easy to adjust the spring tension to the dropped string. It's so easy I even do it live on stage between Songs!
Yes, a D-Tuna is much faster and a more elegant solution, but it limits you to dive only.
I expect the Warmoth order to arrive in May, I'll keep you posted... or keep posting? You'll see!
