The hardest part about trying out some new pedal designs is juggling batteries, pots, switches, jacks and so forth dangling off a breadboard. Lots of hum, easy to get shorts, and the cat always tries to eat it. So I made this puppy... it's basically just an aluminum enclosure with a bunch of breadboards on top and the standard stompbox fixin's... a couple stomp switches, a few pots, a DC jack and two 1/4" jacks.
This gives me plenty of room to experiment with stuff easily. Right now it's just a buffer, but I'll try out some fuzz circuits in a bit.
The input jack, the DC jack, and a fuse holder. On top is just a 1/2 hole with a plastic grommet, for running wires from the inside out.
Here's the buffer I've wired up. A 4558 is actually a dual op-amp so I made two buffers but only one of them is connected right now. One of the LEDs is always on when there's power, the other indicates if the pedal is on.
At the moment, only one of the switches and none of the pots are hooked up. The switch in the middle disconnects the power.
