i know im late on this thread but about calipers and micrometers, in the military we used mostly starrett and i have seen a disturbling number fail to calibrate right out of the box, all of out instruments need to be certified before use on aircraft and the starrets needed some work to get right and i remember one 2-3" micrometer that was binding out of the box, the guy's at the pmel lab said they couldn't do anything with it so before i sent them to drmo i took them apart to find that the hole for the spindle that should be precision honed was galled up pretty badly, even re-honing it hight have freed up the spindle but i would never feel comfortable using them so in the broken tools bin they went. it was a shame because they were carbide tipped micrometers and quite expensive, saying that i have never had trouble with a mitutoyo product, im sure they are not what they used to be but i have a set that is likely from the 70's or 80's and it is vernier not dial and stainless not carbide but i can take a measurement with them as well as a micrometer and lock both tools down and use the micrometer to measure the inside jaws and cant find any deviation, it might be hard to read a vernier scale to the .001 100% of the time but i like them for guitar work and prefer them to dial types because there is no mechanism to have backlash. i have seen many dial calipers with obvious slop in the dial, turning the dial face to zero them out often causes the needle to move because the jewels all change alignment, typical of imports(which probably aren't jeweled) or anything that has been well used.
i would like some nice carbide digital calipers and carbide tipped mics but cant afford it right now.
as for the $30 specials from china they can be useable and considering the lower standards that i am seeing from starrett may be a better buy but never buy a set blindly. always hold the jaws up to the light when they are closed to check for parallelism. or bring the gage blocks with you and test at different areas of the jaw. do the same for starrett as well. i had a 0-1mic starrett in tech school that zeroed out but always gave me different numbers when i measured round parts. holding them up to the light revealed an obvious problem, those were old and may have been dropped and re-cal'd by another student that tried to cover it up as far as i know but i was a definitely aggravated with it.
the only b&s tools i have worked with are parallel blocks, gage blocks ect. well i have used very old b&s mic's but not sure what the new stuff is like. i never hear bad things about them though. if it were me i'd have bought the mitutoyo's first but glad you found some decent tools. it can be hard this day and age where it would seem precision manufacturing and QC are a dying art, the specialists may be getting more specialized but thing aren't getting passed down.
