Countered heel screws
gouzos
Does anyone know if these screws: S8  Neck Screws, Set of 4 (2 Long + 2 Short) for Contoured Heel, Stainless Steel, Black from the Warmoth site
are absolutely safe for use with the countered heel body?
Also, on which positions do the short ones go? (I know, not a very smart question, but I can't really tell)
Orpheo
you just have a look at the guitarbody and neck, and you just see were there body/neck connection is at its slimmest.
gouzos
Well, the neck plate area tapers in both directions. So the innermost one toward the body obviously is a long one. The opposite one, the outermost one, is a short one.
I'm not sure between the other two.
gouzos
Alfang, I figured that out for myself. I also figured out to use the shortest screw for the most shallow hole.
However, I end up with 2 holes left that are basically of the same depth and a long and a short screw.
dbw
Take the neck off, put the bolts through the heel in both possible configurations, and see how far the bolts stick out?
simple
Staff member
The two short ones go on the side closest to the peghead of the neck.
