I grew up with an SG wired V-V-T-T, and it's really useful - ONCE YOU GET USED TO IT. I have it on most of my "real" guitars and I keep the 3-way in the in-between position at least 2/3 of the time. It's actually quite rare that the neck tone isn't full up, but the whole system is interactive - I've tried wiring a guitar with volume only for the neck PU and V-T for the bridge, and it didn't DO me, for some reason. The key to it is set the volumes around 7, and the bridge tone around 6 or so, 500K pots all around and a bright rig otherwise. Most of the famous English Les Paul guys had a treble booster in there, Duane Allman & Carlos Santana (on the first four albums at least) used bright-ish hi-fi speakers with less of a high-frequency rolloff cliff than Celestions or such. Altec-Lansings for Duane, JBL's for Santana (IMO, everything he did after Caravanserai was a rehash - like the Stones, his discography through the early 70's made the man).
So you set up your amp to sound perfect with the guitar rolled back a ways - then everything you need is at your fingertips. Duane's solo on the Live at the Fillmore "In Memory of Elizabeth Reed" is your master class - listen to what he's doing. Page could work the hell out of that too. Adding a series-single-parallel switch on your humbucker's even more stuff. The pickups are highly interactive, but that's the point of it. Here's a concert that's better than the Fillmore album, the sound's lesser but the playing's better - it was the closing concert of the Fillmore East.
http://tela.sugarmegs.org/_asxtela/AllmanBrothersBand1971-06-27FillmoreEastNYC.asx
(when Dickie was playing well, Duane took it personal, like - the slide solo at 11:10 - Derek WHO? :toothy12: Do NOT skip ahead to 27:50.)
Somebody just dumped a MOTHERLOAD of Allmans w/Duane recently, dig:
:hello2:
