I have Nomad that I need to put together, and I have some pickup questions for you.
BOSS has new MIDI pickups using TRS serial cables, where one can use them on a GM-800; this is their kit for permanent installation. This is the installation documentation. Has anybody tried to install one? Did you learn any lessons that you'd be able to share?
From what I can tell of the instructions, it has these controls:
* A 3-way switch ("GUITAR/MIX/GK) that controls what goes down to the GM-800.
* A momentary switch; it seems to send events down to its GM-800 controller, perhaps it can be used to trigger MIDI stuff, I'm not sure.
* GK volume, where I have a free knob hole to put this
* A LED indicator (that seems useless, I'll probably skip it).
It seems that I need two output jacks.
Next, I was going to drop in two Fishman Fluence Modern pickups. Unfortunately I ordered the body routed for pickup rings, and it doesn't seem that Fishman sells rings; where could I find them? I was actually interested in their Open Core Modern Humbucker because I think it might look cooler, but would it fit in a ring? Any thoughts? And it seems to come in ceramic or AlNiCo magnets; is there anything that makes more sense? (I usually play neoclassical metal stuff, but I don't really know.) I am guessing that I need to wire them like this because I'd only have two pots left given that the MIDI pickup would take one up. That would add two more toggle switches, so I'd have four of them, total. (I'd just put them in a row, but I'm not sure exactly where, yet.)
Any thoughts/advice? Thanks!
