NovasScootYa
Micro Mesh cloth sheets range from 1500 to 12,000 grit and work very well for a slick finish on wood, frets, etc.
Unfortunately exotic wood necks have the same dimensions as unfinished maple necks and unfinished maple necks are undersized to accommodate the additional thickness of a Warmoth applied finish or a customer required finish. For the profile of an exotic wood neck to feel correct either treat it like maple and apply a finish or convince Warmoth to add a minimum .006” thickness to the profiles of exotic wood necks.
I know .006” doesn’t sound like much but it means a neck with a finish is around .006” thicker on the bottom and .006” thicker per side. To feel the basic difference between finish and no finish simply apply strips of blue 3/4" painter’s tape to each side and along the bottom of an unfinished neck.
