Black Korina Mooncaster
seelaba
Assembled and finished by
CML
Canadian Made Lutherie
Mark's Custom Shop
Body
Construction: Carved Top - Hollow
Core Wood: Black Korina
Lam Top Wood: Black Korina
Control Cavity: Rear Rout (Standard)
Neck Pickup Rout: Humbucker
Bridge Pickup Rout: Humbucker
F-Holes: 2 F-Holes
Controls: Volume 1, Volume 2, Tone 1, Tone 2
Toggle Hole Jack Rout: 7/8" (22mm) Side Jack Hole
Bridge Rout Type: Hardtail
Bridge Rout: TOM/STP (Angled Pocket)
Mounting Holes: Standard 4-Bolt Neck
Pocket Shape: Strat®
Body Contours: Tummy Cut, Contoured Heel
Binding and Edge Decorations: White Binding (Carved Top)
Neck
Construction: Modern
Shaft Wood: Roasted Flame Maple
Fretboard Wood: Ebony
Nut Width: 1-11/16" (43mm) - Modern Medium
Neck Back Profile: Standard Thin
Fretboard Radius: 10" - 16" Compound
Number of Frets: 22
Binding: White Binding
Fret Size & Material: SS6100 - Jumbo (Stainless)
Tuner Hole Size: Schaller/Modern Fender/Sperzel (25/64")
Inlay Shape: None
Side Dots: Black Side Dots
String Nut: Standard Nut - GraphTech White TUSQ XL
Neck Heel Shape: Strat® Shape
Parts/Electronics
Seymour Duncan P-Rails w/ Triple Shot Mounting Rings
Ibanez Quik Change III Bridge and Tailpiece
Fender Staggered Post Locking Tuners
!!! That looks great. What's the finish on the body?
So my dad was the one who finished and assembled it (he's the Mark in Mark's Custom Shop). For the body he did a coat of natural stain and a coat of cherry stain, then Keda dyes for the amber in the centre and the ebony/red burst. Finished with a high-gloss poly. The neck was just a coat of natural stain, then satin poly on the back and high-gloss poly for the front of the headstock. The decal is his logo (if you look close you can see it says "CML," which is the initials for Canadian Made Lutherie (also happens to be my initials 🙂)
