Common reasons for inconsistent tuning:
- A tuner that doesn't hold position due to slack/backlash/poor winding
I had this issue with 1 Shaler mini locking and it was due to the fact that the screw, the one that goes through the knob and adjusts the tension of the tuner, was too loose.
HOWEVER ... it didn't *feel* loose, the way all other tuners have felt to me in the past, when they need adjusted.
It felt just like the other Shaler mini ones on the guitar that were performing correctly.
BUT ...
Tightening the screw made the tuner perform perfectly, where as before tightening, the back lash was enough to drive me to start looking for a binding nut issue.
I actually started filing the edges of the nut trying to fix the issue.
When the nut file job didn't fix the (supposed) binding issue, I had to, logically, look else where, and found the adjustment screw issue.
so .. BEWARE ... the Shaler mini is a tricky little devil if not properly adjusted.
