bob7point7
OK, so I've assembled most of my LPS now, but I discovered that it isn't balanced well at all. Here are the specs:
LPS chambered mahogany body with carved mahogany top
2 humbuckers, tune-o-matic bridge
Wenge neck with Warmoth headstock and '59 roundback contour, ebony fretboard
Grover Locking Rotomatic tuners
Front strap button mounted on the upper horn
I guess the combination of a chambered body, short upper horn, and wenge neck with a thick contour made for a pretty neck heavy guitar. Does anyone have any suggestions for correcting this? Are there any tuners that would be significantly lighter? Has anyone ever ballasted a guitar by adding weight in the control cavity (I was thinking of maybe adding lead tape to the inside of the control cover plate)? Any advice would be much appreciated. I'm not looking for miracles, just an improvement over the current situation.
Thanks,
-Bob
On a side note, everything else has worked out great so far....
Thanks,
-Bob
