Fdesalvo apparently had problems with the neck pocket on his recent Velocity (Trinity) build such that the TOM is not providing enough counter-tension on the strings to keep them in the saddles. My recent VIP build (Ansel) might have a similar problem.
My VIP has a non-recessed Floyd Rose, which is supposed to use an angled neck pocket similar to bodies that use a non-recessed TOM. I did not notice this when assembling the guitar, but after picking it up from my local tech (level/crown/polish the frets, intonate, and neck adjustment/setup), it seems the base of the Floyd Rose is actually resting on the body. I'm pretty certain that, even in a non-recessed application, it still is supposed to be a floating tremolo (just with limited pull-up abilities). This is the first non-recessed Floyd guitar that I've built, but I think if the neck pocket was properly angled, the Floyd should be above the body and floating between string and spring tensions.
I guess the first step is to return it to the tech to see if it can be corrected in the setup. If not, either a call to Warmoth and/or neck pocket shims might be the next step.
Thoughts?
Thoughts?
