DangerousR6
Mythical Status
I think I found the perfect name for this one... :laughing7:
http://www.youtube.com/watch?v=RR0Qh7pseos
Not on the lips, I bet I can string my Floyds just as fast if not faster than any other trem... :icon_thumright:Cagey said:You kiss your mother with that mouth?
And while I'm castigating... you do know you're going to have to put strings on that thing, right? Doesn't matter how pretty it is, you gotta do the string thing. Don't worry - it's not like stringing up a Floyd. You'll not only be able to get it done between meals, you'll have time to play it, too!
Good point.... :icon_biggrin:Cagey said:Y'know - it occurs to me that you don't have to ground the bridge. You can drill/tap a 6-32 x 1/4" hole anywhere in the control cavity, put a spade lug on a wire and clamp that under the screw. Your bridge/strings will end up grounded because your whole body/frame is highly conductive. For that matter, you might not need to run a ground wire at all. The output jack is automatically going to ground the whole body.
Which means, when you gotta ground a wire, you can just solder it ANYWHERE.DangerousR6 said:Good point.... :icon_biggrin:Cagey said:Y'know - it occurs to me that you don't have to ground the bridge. You can drill/tap a 6-32 x 1/4" hole anywhere in the control cavity, put a spade lug on a wire and clamp that under the screw. Your bridge/strings will end up grounded because your whole body/frame is highly conductive. For that matter, you might not need to run a ground wire at all. The output jack is automatically going to ground the whole body.
:laughing11:Jumble Jumble said:GUYS I WAS JOKING ABOUT SOLDERING TO THE BODY JEEZ
