This is my first all-Warmoth build, and first from scratch finishing project (I refinished a camouflage Dean Vendetta a few months ago -- that was my "learning" project, and actually it turned out ok). This is an alder j-bass body paired with a birdseye/rosewood neck.
I like the grain pattern here a lot -- it's subtle, but should show nicely through the stain and Tru-oil finish it's going to receive. Here's the neck (with a Warmoth stain finish):
Yesterday was spent sanding with 320 then 400-grit paper, then I gave it two wipe-downs with water to raise the grain, sanding with 400 after each, since I'm using a water-based stain (General Finishes Dye Stain). Then a nice little naphtha wipe-down to clean things up. Here it is after the first coat of stain:
Despite the two rounds of wetting and sanding, the stain still raised a bit of grain and roughed things up a bit. The back, as you can see, is a bit splotchy, so today's project will be a light sanding, probably with a grey 3M scotchbrite pad, then reapplication of the stain, which I'm hoping will make it both richer and more even. Yea, it's orange. What can I say? I like orange (black-white-black pick guard should like nice against it).
After the second stain coat has dried, I'm going to coat with Birchwood Casey sanding sealer and let it dry for at least a day, which should give a nice, smooth surface, then it's time for the Tru-oil.
