ragamuffin
This build is my take on the EB Musicman Albert Lee. I wanted to go for a retro-modern aesthetic with quality, modern features and tailor it to my own tastes and preferences. Loving the result!
-Standard thin warhead neck in wenge with an ebony fretboard and no inlays. SS6105 frets and graphtech nut
-Body shaped from a rear routed Warmoth mahogany blank. Contoured heel, slightly relocated screw position, and countersunk ferrules.
-Finished in burgundy mist metallic nitro by Greg Grubaugh who did a beautiful job!
-Seymour Duncan Seth Lover and SL trembucker pickup swith raw nickel-silver covers, A4 and A8 magnets for a more balanced eq, tighter bass, and slightly higher output sound while keeping some vintage sweetness. The pickups are direct mounted using small threaded inserts and machine screws without damaging/modifying the pickup baseplates.
-Volume, treble, and basscut knobs, three way switch, and a push pull for a semi-out of phase middle position
-Hipshot contour bridge and locking tuners
-Trem tip, switch tip, and bass knob made of wenge by David King/Dknob
