DangerousR6
Mythical Status
This is showing off... :icon_biggrin:
	DangerousR6 said:This is showing off... :icon_biggrin:
That light needs chrome or nickel hardware.swarfrat said:That there's just showing off.
	True... :doh:StubHead said:I would kind-of guess that because he bought a body with a whammy hole, he probably wants a whammy... not everyone here yet realizes that you should buy a whammy bod just to cover it up!
Kind-a like the suddenly universally-known internet/guitar fact that the specific reason to buy a guitar with a thin nitro finish is that you can wear it off quickly and then you'll be cool.
I used a 2 part 2-ton epoxy on this spalted maple top, it cured hard as a rock. Surprisingly epoxy will polish to a nice shine too..StubHead said:I have a fair amount of casting epoxy lying around still; it's the 2-part stuff that hardens up to a solid, heavy dense plastic as least as heavy as hardwood. If I somehow saw a completely irresistible body, only half-mutilated (AKA tremolo routing "your choice") I wouldn't hesitate to fill the spring hole with it. Hey - maybe I should order a body with tremolo routing, just so I can fill it up.... ???
	StubHead said:I need to ask, what brand(s) of sandpaper were you using during everything besides the last 3M polishing paper? I luckily discovered that the "synthetic steel wool" that I was planning to do my anti-French polishing Tru-Oil finish with actually kicks out a whole bunch of stuff that is much closer to "sand" than to "grain filler." I'm familiar with the old gray wet/dry paper, but in doing a bit of reading it seems there are new miracles in Sandpaperland? Or is that just the Stew-Mac blurb department at full throttle... ???
