Acoustasonic conversion?
Nomad and Arcade necks would work also, but may not look good on the Acoustasonic
@dc.git as @Mitch pointed out a conversion neck will need to have a tilt back
A modern construction neck which the conversion necks are unless it is a tilt back has a side adjust on the straight headstocks which is incompatible with the body.
In the picture from the Warmoth website in your previous post, to the left of the "area of incompatibility". Do you foresee a problem?
There is not much room to the left of that position on the neck plate for a hole to go through.
