Super Turbo Deluxe Custom
Epic Member
Dropped it off for a fret level, nut install, crown and polish.
StubHead said:Well, I just stared at em, and yeah... The steel guitar non-locker has a regular longish post with an oval hole that could use a bit of cleanup. The locking ones have a deep slot milled around the head, and the hole is the full width of the slot - so you can't get anything round in there very easily. But as the string is coming in straight from the slot, you could at least soften the sides of the hole with a little oval file, round pippen file or the like. Shrapnel in the gears would be no fun, but then if you turn the lock all the way on, that seems to be closed up. You can also take them completely apart - kind of a pissy way to while away an afternoon - "maintaining equipment" and/or modifying it is so-oo 20th century.... I wonder if the reason the steel guitar Sperzels work so well is because steel guitarists write to Sperzel if something goes wrong? Weird enough to have disposable amplifiers, but when you just start throwing away guitar parts? eeek. Brave New World. Creak, creak, zzzt... thud. pbpbpbpbpbbp
