Indyplumber
I'm considering using dye on quilt maple but I'm still a little confused on the steps. It seems simple enough. But the question I have is when or even if to use wood filler or sanding sealer? Those two items I don't believe are the same thing but sometimes I see them mentioned as if they are. Are they?
If I was to dye I am assuming these steps?
1. Sand lightly with 320 then clean with air and/or tac cloth
2. Apply Dark or Black Dye to taste, sanding back
3. Apply Main Dye Color to taste
4. ? Filler? Sanding Sealer??? Nothing?
5. Clear Coats
6. Wet Sanding from 320 to 2000
7. Buffing
After applying the dye what step is next? ???
5. Clear Coats
7. Buffing
