jackthehack
Epic Member
Did a quick test shot of the toner; look like Behlen Walnut Medium brown is dark enough to mask the mahogany coloration difference between neck and body and pretty damn close to the original as can be seen from the below (pic of neck/body comes out a little darker than actual).
As is often the case, the neck needs another fill that can be real hard to discern from sanding sealer coat, but immediately obvious with toner application.
Tip: When filling grain with dark/colored filler, easier to do last fill or two with clear. You still have the coloration in the grain, but easier to sand back without pulling filler from grain pores if you're not also trying to remove coloration from rest of wood, and the color still shows fine.
This Behlen toner is THIN; going to stick with it as this solves my color issues, but has to be applied in EXTREMELY thin coats, just barely laying any down and slowly building up toner layer.
