bbl4ck
line6man said:bbl4ck said:Funny, I am looking for the same thing; almost! I want coil splits and serries/parellel,
Volume, Volume, Tone, Neck pickup series/single coil switch, Bridge pickup series/single coil switch, Master series/parallel switch?
I have a diagram of this that i drew for a guy with stacked humbuckers on a Jazz bass, but both pickups go split to the north coil.
I would assume that you want the neck pickup to split to the north coil, and the bridge pickup to split to the south coil.
Here is the diagram, but i can change it to split to south coils.
Hey line6man,
I can't thank you enough for sending the diagram :headbang:
I have been looking through electronic books and diagrams for some time and have not been able to come up with this exact diagram. Lots out there using 2 volume & 2 tones, but not 2 volumes & 1 tone.
This is my first build, so when I do the wiring I will spend some time playing around with things so I can get a better understanding of guitar electronics.
Yes, the neck pickup to split to the north coil, and the bridge pickup to split to the south coil would be ideal. However, I do not want to put you through any more work changing diagrams. You have already done enough!
If you could just explain the change that would be cool :icon_thumright:
Also, I am assuming that like in your other diagram, the mini-switches are DPDT on-on?
Thanks again and hope you have a great weekend!!!
