Bagman67 said:Having chewed up some inexpensive guitar bodies lately, I'm all in favor of paying someone who's got a record of demonstrated mastery of the arcane arts of assembling and setting up a guitar to do it when I've invested a pile of dough in the components. My technique and confidence are improving but I'm not ready to just go for it on $1000 worth of expensive kindling. We all started somewhere.
Torment Leaves Scars said:If setting up and building guitars was so easy, there wouldn't be luthiers, would there?
Cagey said:Torment Leaves Scars said:If setting up and building guitars was so easy, there wouldn't be luthiers, would there?
It doesn't take a "luthier" to do most of that stuff. That title is bandied about much too freely. Just owning a Phillips screwdriver and a soldering iron and knowing the names of the parts and where to get them doesn't make you a luthier.
I've done a ton of finishing, modification, assembly, setup, fretwork and electrical on guitars over the last 35 years or so, and am considered pretty good at it, but I would never in a million years consider myself a luthier. That would be like a building contractor calling himself an architect, or a computer tech calling himself an electrical engineer, or a web page creator calling themselves a programmer, or Death From Above 1979 calling themselves musicians <grin>
Still, that doesn't mean it's easy or that it doesn't take a certain amount of talent and experience. Not everyone can do it. If that were the case, there'd almost be no OEMs. Everybody would just do it themselves. Hell, there are people out there who can't even make a decent sandwich for themselves. How on Earth would they ever handle building a guitar?
Orpheo said:thats why we are here: to save you money and to guide you through your first build. Rome wasn't build in a day too, you know.
Torment Leaves Scars said:While I don't doubt you would be able to "guide" with instruction, you can't, however, "guide" the hand behind the soldering iron or screwdriver.ccasion14:
jay4321 said:I can testify there's definitely some potential for mistakes when your first DIY is an expensive custom Warmoth. Over the years I've learned some fascinating lessons, such as:
- How easy it is to slip with an electric drill when putting pickguard screws in; just use a screwdriver
- Not forgetting to use shorter screws on contoured heel Warmoth necks (didn't do it, but came pretty close)
- A nice soldering station does not make you good at soldering
- Wiring diagrams are not always accurate
- Nut and saddle filing is best not learned on a nice instrument
- Setting up a guitar properly requires the right tools, a number of them, and none are free - if you only own a guitar or two you're definitely spending more money in the short term
- I am not Dan Erlewine, no matter how much crap I buy from StewMac
- It's really important to drill the right size holes for string trees
But mostly, the biggest lessons are that my time has a real value and I that don't overly care for setup work. If I tried to go DIY for every potential job that I came across (not just with guitars but in general), I usually wouldn't come out ahead. For example the money I might save installing a fence myself--which I know I can do, from experience--would cost me even more in lost time & money elsewhere. Unless I liked doing it (I don't) there really isn't a good reason not to hire a pro.
With guitars, I'll change out pickups and do a few basic adjustments here and there but leave the finer work to someone better at it, it doesn't cost that much. Someone who's not experienced at all is going to make mistakes though, and that will come after they've already invested in things like a set of nut files, radius blocks, fret files, soldering kit and so forth.
