Yogevs
Hello wise people,
Does anyone have some experience with wood mounting noiseless single coils?
There are two issues that concern me:
1) Noiseless are somewhat taller than regular single coils. Would they be compatible with a rear-router Warmoth velocity body?
(Some numbers: Warmoth pickup socket depth: 19mm, typical single coil height: 18mm, SD STK-S4 height: 22mm, Fender ultra noiseless height: 25mm)
2) There are metal nuts built into the pickups that cannot be drilled out without damaging the pickup (attached picture). Do you think I can simply use screws that are thin enough to pass through the nuts?
Thank you!
Thank you!
