November 2022 Guitar of the Month Submissions
GOM
We are now announcing the November, 2022 Guitar of the Month contest! November's contest will be "Warmoth/professionally finished" and requires at least a Warmoth neck or body to qualify.
Please read the GOM rules, which have been refined, with some slight changes, and are posted in a sticky in this forum area.
Submissions must be sent to uwfgom@gmail.com, and contain two images no greater than 1024x768, along with your description and details of the instrument. Send your submission in plain text email. Your photos must be attachments to the email. Your UnOfficialWarmoth Forum user name must be included in the body of the email.
In turn, your images will added to this message, which is November's submission thread.
Submissions will be accepted until exactly 7 days from the date and time of this post, so get your cameras clicking!
As usual, discussion about the submissions can take place below.
Please do not post additional photos in any replies to this thread. Links to other UW threads or external sites are fine.
Please try to stick to the entry requirements:
Two 1024x768 pixel images maximum as attachments please, not embedded in the email or linked to external sites.
An image for the purposes of this contest is a single photograph, not a multiple image/collage.
Include your UnOfficialWarmoth Forum user name.
Warmoth or other professionally finished instruments only this month.
Sorry, but entries that do not meet these requirements may not be included in the contest. If you're having technical difficulties, get in touch! (But only about contest entries please!)
Good luck, and may the best guitar/bass win!
Guitar #1 AngeloGuitars
Body:
Warmoth Velocity
Solid construction with 1-piece mahogany
Quilted maple laminate top
Forearm contour
Tummy cut contour
Heel contour
Natural masked edges
Black dye with black burst over
Gloss
With Lollar Imperial low wind humbucker pickups
Neck:
Warmoth Warhead
Gibson scale conversion
5A Roasted Flame Maple
Black ebony fingerboard
Wizard profile
10"-16" compound radius
22 frets
Stainless steel frets SS6150
Schaller locking tuners
Graphtech Tusq nut
Moon glow side dots
Diamond white perloid dots
Guitar #2 mjlee
NECK
Warmoth, roasted maple, unfinished, Indian rosewood fretboard, standard thin, stainless steel SS6150 frets, compound radius, GraphTech TUSQ XL nut, 1-11/16" nut width, 24-3/4" scale length.
PICKGUARD
Aluminum
BODY
Warmoth, SSS rout.
Finished with wood dye and a light coat of satin lacquer
ELECTRONICS
Bridge: Seymour Duncan Litttle '59 humbucker
MIddle: Fralin Blues Special
Neck: Fralin Blues Special
5-way selector
3-way mini toggle gives 8 pickup combinations: all 7 single coil combos (HB split), plus HB
1 volume control, 1 treble control. (Black rubber plug fills 3rd hole, flush to pickguard.)
Chrome pickup covers, brushed with ScotchBrite pad.
BRIDGE
Callaham stamped saddles, tremolo, and block. 3 springs.
TUNERS
Fender locking, staggered
Guitar #3 docteurseb
Body:
Warmoth Stratocaster
Solid construction with swamp ash back and quilt maple
Heel contour
Quilt top stained by myself in a PRS-style charcoal/frostbite glow finish. Wilkins Guitar Finishes did the cerused / dog-hair back and clear gloss finish,
Fender Vintage Noiseless pickups with Eric Clapton mid-boost electronics
Neck:
Musikraft quartersawn curly maple with ebony fingerboard
Clapton V profile
12" radius
22 frets, stainless steel
GraphTech nut
MOP side dots
Gotoh locking tuners
Stained a set of curly maple tuner buttons to match the neck/body.
Finish: stained neck with lacquer finish (satin back, gloss headstock) - DIY finish.
Guitar #4 Max Headroom
"Number One" (because it is my first ever guitar build)
Warmoth Telecaster® Replacement Guitar Neck
Construction: Vintage/Modern
Shaft Wood: Flame Maple
Fretboard Wood: Flame Maple (One-piece)
Nut Width: 1-11/16" (43mm) - Modern Medium
Right / Left Handed: Right-Handed
Neck Back Profile: Standard Thin
Fretboard Radius: 10" - 16" Compound
Number of Frets: 22
Fret Size & Material: 6150 - Wide & Tall (Nickel)
Tuner Hole Size: Schaller/Modern Fender/Sperzel (25/64")
Inlay Shape: Diamonds
Inlay Material: Black Pearloid
Side Dots: Black Side Dots
String Nut: Standard Nut - GraphTech Black TUSQ XL
Mounting Holes: Standard 4-Bolt
Neck Heel Shape: Tele® Shape
Finish by Warmoth: Clear Gloss (Maple/Maple)
Warmoth Tele® Replacement Body
Construction: Solid
Core Wood: Alder
Control Cavity: Top Rout
Neck Pickup Rout: Tele®
Middle Pickup Rout: None
Bridge Pickup Rout: Tele®
Jack Rout: 7/8" (22mm) Side Jack Hole
Bridge Rout Type: Hardtail
Bridge Rout: Vintage Telecaster®
Neck Pocket Shape: Tele®
Body Contours: Forearm Contour, Tummy Cut, Custom Contoured Heel
Paint Category: Burst
Top Color: Black to Clear Burst
Back Color: Black to Clear Burst
Finish by Warmoth: Gloss
Gotoh Standard Tele® Bridge-gold
Warmoth Telecaster® Pickguard, Black/White/Black, 8 Hole Tele®
Bare Knuckle Pickups: Boot Camp-True Grit neck and bridge
Fender® Super 250’s 10-46 strings
Fender® Locking Tuners-gold
Fender® Control Plate-gold
Fender® Straplocks-gold
Obsidian Wire Wiring Harness: Vintage Plus '3-way' for Tele®
Gotoh Knobs-black
Fender® switch tip-black
Warmoth string ferrules-gold
Warmoth electrosocket jack-gold
Perri’s Leathers guitar strap
