Wishlist - 7/8 Warhead tiltback
jjwu
Any support among the people for a 7/8 Warhead neck with Modern Tiltback construction? Can we make this happen? Power to the people!
I can't think of any advantage to have a tilt-back neck. The added break-angle causes addition friction at the nut, and it makes the tuning stability worse. Why do you want this?
Now that y'all mention it, Aaron did a video on 7/8 showing that they built the 7/8 neck by putting a short scale fretboard on a standard scale blank. So it certainly seems they could take any of their 25.5" tiltbacks and slap their 7/8 fretboard on it.
A well cut and polished nut should be mandatory regardless of headstock design and alleviate any of those symptoms. Also, no string tree or staggered tuners needed.
Except, a fretboard is not slapped on. It would require a separate CNC program.
A 7/8 tiltback is not a slam dunk. Given the R&D involved and the percentage of total sales it accounts for I imagine the 7/8 offering will likely remain just as it is for some time.
But hope springs eternal...
How so? Are you saying the normal 25.5" 22-fret fretboard is CNC'd differently for the modern vs modern tiltback?
I am saying it is not as straightforward as just putting on a different pre-cut fretboard.
These are engineered in context at concept stage in order for them to be able to have the end result of being able to simply mount/bolt up, and intonate.
Put me in the "I won't buy a 7/8th's, or any neck, with the side truss rod adjust doo-hickey and without headstock truss rod adjustment". Yes, I'd love either a Vintage/Modern, or Tiltback with single truss rod.
The potential for the 7/8th's is up there, but it's limited by the offerings for this series. I'd even love a 7/8th's body blank to play with.
The body blank with just a neck pocket would work, of course, you would have to measure and rout for your bridge and pickups etc.
Would a 7/8 paddle neck be in the cards?
