Mayfly said:did you connect the humbucker link wires together? You'll need to do that or you won't get any path to ground in the non-tapped setting.
The Aaron said:Mayfly said:did you connect the humbucker link wires together? You'll need to do that or you won't get any path to ground in the non-tapped setting.
Yep. The 6-string humbucker is wired thusly: red and white twisted together, connected to grounded terminal #2. Black wire to hot terminal #1, then jumped to #2. Green and silver to ground.
Mayfly said:Hmmm yea that should work. If you have a DMM you can check the operation of the switch in the various positions to ensure you've got connectivity when you expect it.
stratamania said:Perhaps also try the wiring on another pole of the switch as a possibility. Or is there any solder dripped onto the workings of the switch or a terminal bent. You should be able to see the blade of the switch make contact at the various positions when you select them.
Really? I'm pretty sure they used plastic boxed switches that melt if you hold the iron on the tag too long :dontknow:swarfrat said:That looks like what I remember from my 90's Ibanez RG.
