Wiring advice please?
Steve_Karl
Greetings!
I'm down to the final steps of finishing my build and I have a question about wiring.
Should these hot lines (see attached image - blue arrows point to connections I ask about) be shielded cable or is just a single piece of wire OK?
Thank you!
Steve
You dont need shielded wire for those connections. unless the 3 way is in an LP style location but just using some regualr humbucker wire will be fine.
Sorry what I meant by "shielded" was say cloth push back wire. Not bare wire.
OK
I get it now. The reason I originally asked is that the only shielded wire I have here now is pretty thick.
So, "cloth push back wire" - (never heard the phrase before) - would just a normal piece of plastic insulated wire be OK?
OK
yep!
