Neo Fender
...Strat Pickguard
I’m mentally working up a pickguard for a Stratocaster build. Today, my thoughts are on a two humbucker, two volume and two tone setup using a spin-a-split wiring scheme.
I’ve seen four potentiometers in a Strat cavity and it looks like more like a science project than a serious guitar, therefore I’m thinking two stacked (concentric) potentiometers; neck volume/tone and bridge volume/tone. I understand, Warmoth will drill a pickguard with just two potentiometer holes. I could go this way and would probably leave the Control 1 spot (closest to the bridge) empty, as I’ve inadvertently spun that volume control down more than once – not something you want to do in a middle of a jam, outside of Madison Square Basement.
Another pot? Another switch? I don’t need a jack there, as I already have the angle mounted football jack. Don’t want or need a kill switch either.
Thanks.
Thanks.
