ChrisMC
Hey all, so as I’m waiting for my neck and body to arrive (I’m at about the halfway point), of course I’ve been brainstorming with how exactly I’m going to wire my two humbucker Soloist, and I think I’ve more or less decided, but wanted to ask here to see if there’s anything I haven’t thought of that might be cool.
So I’m doing a 5 way blade switch as follows:
1. Bridge humbucker full
2. Bridge split with south coil active
3. Neck and bridge split with inner coils active
4. Neck split with north coil active
5. Neck humbucker full
I’ll have a blower switch/straight to output switch wired to the bridge pickup via an on/on DPDT mini toggle.
And then I’ll have a treble bleed bypass switch via an on/on DPDT mini toggle (removes the treble bleed circuit when engaged, for when you WANT it to get dark when you roll down the volume, which sometimes is a desirable tone).
Master tone
Master volume
What other things have you tried via mini toggle (or push/pull pot...DPDT, same thing, I just very much dislike push/pull pots because they’re hard to pull in a live situation while holding a pick).
I was just curious. Thanks!
Master tone
Master volume
