Warmoth Goncalo Alves neck
vjm
$125... the tuner hole placement pegs I messed up a bit when drilling, does not affect anything(NOT THE TUNER HOLES)....see pics
Style: Stratocaster®
Construction: Vintage Modern Construction
Orientation: Right Handed
Neck Wood: Goncalo Alves
Fingerboard Wood: Goncalo Alves
Nut Width: 1-11/16"
Back Shape: 59 roundback
Fret Size: 6150
Tuner Ream: Sperzel (25/64")https://www.warmoth.com/Showcase/images/necks/medium/vms4807a.jpg
Radius: 10-16" Compound
Scale: 25-1/2"
Fret #: 22
Mounting Holes:
Pre-Cut Installed String Nut: GraphTech White TUSQ - Standard Nut
Inlays: Cream Face Dots
Those two tuner locating pin holes being oversize, will still work ok or you could fill with small dowel rod and red-rill them.
Yep....the tuner holes are fine. I had the neck on a strat build and worked perfectly. I am just addicted to the 1 3/4 nut so I replaced this neck with maple w/.75 nut.  :occasion14:
