Warhead Headstock
Should the Warhead headstock be listed and offered as standard for "Pro" necks
  • Yes
    Votes: 75 88.2%
  • No
    Votes: 10 11.8%
  • Total voters
    85
Phrygian
I think the Warhead headstock should be listed as a standard option for the Warmoth Pro necks.
Wyliee said:
NonsenseTele said:
I think this is the Warhead:
Yup.  That would be the Warhead.  I'll try to get a shot of my Pbass with a Warhead neck and post it.
-Eric.
Alfang said:
Ok, I gotta ask this. is the warhead basically a fender headstock with an extra scallop taken out of it?
I think it is a bitchen look, i like it a lot.  I also like the green that everyone is using as an example here.
m4rk0
Yes on the first question!
most likely CB on the second! :)
is it me or is the shape of Gregg's Warhead slightly different?
either way, I like them both!
simple
Staff member
Well, they're supposed to be the same...
We do have to cut these heads by hand so it's possible to vary a bit, but I suspect these two heads look different because of camera angles, lighting and software files.
m4rk0
Yes you are right, I think the contours of the Green one look sharper because of the green/natural line.. (if that makes sense.. :icon_scratch:)
G
guitlouie
Phrygian said:
Now I want to know who would vote no on this?  CB?   :laughing7:
I want to know who would start a poll and expect to get only one kind of answer?
Wyliee
Sir Schmoopie said:
i think it should be available for bass to also as well
It is!  4 string and 5 in line Deluxe 5.  Just ask your sales rep for it when you next order.
-Eric.
Shmoopie
i heard there was an up charge for the last guy. but either way im happy. that would look awesome on a g4.  with hipshot hb1s and a d tuner. and a hipshot string retainer.
Wyliee
Finally, here's a shot of my Warhead equipped P bass.
Well.... at least it is the headstock.
Undertaker4
What is the charge on this headstock?  Also, does it start with the options from Paddle or Angled Paddle to determine wood options?
AGWAN
Oh, this is nice... I think it would look better on an Iceman than the Arrow, which is what I'm currently considering.
Kostas
Check the Kenneth Lawrence and the Warmoth headstocks for an Iceman body.
